B&S voltage regulator
Have a B&S 20G414 running Simplicity snowblower. Voltage regulator 698315 has output of 13.5 vdc at idle and 14.6+- vdc at full speed. Blowing 1156 single contact bulb at full power??
Any thoughts as to output of vr or rating on bulb?
tks js
tks js
Your voltage is fine. I suspect low-grade (chinese) bulbs and/or excessive vibration causing the bulbs to blow.
Any Luck, Have same problem
Can you let me know what you figured out. I'm having the same problem! I got 20amps at the bulb at first start up then 14 at idle.. Blew 3 bulbs so far
Thanks
Steve
Thanks
Steve
amps or volts ?
