2 cycle carb adjust
What is the correct proceedure for adjusting the high and low idle on the carb on a Craftsman weedeater? model 358.797260
Brett
Brett
Hi:bbartels
I would suggest setting the LOW speed adjustment to one and a half turns OUT and the HIGH speed adjustment setting at two and a half turns OUT.
This would be about correct for initial settings to get the engine running. From that point the final adjustments can be made.
The final adjustments may need the LOW speed setting set about 3/4 and the HIGH speed about 1 and 3/4 turns out.
Keep in mind a 2 cycle engine should always be set just slightly richer on the HIGH speed setting since the fuel & oil mixture is the only lubrication for the engine.
Good Luck
Sincerely,
Sharp Advice
Trade:Natural Gas Energy Consultant & Technician.
Appliance Service & Repairs Rep.
Vocations:Saw & Tool Sharpening. Small Engine Repairs.
Accurate Power Equipment Company.
Personal Quote:
"Drive Safely. The Life You Save, May Be Your Own."
Good Luck
Sincerely,
Sharp Advice
Personal Quote:
quote:<HR>Originally posted by Sharp Advice:
Hi:bbartels
Good Luck
<HR>
Thanks Tom
Brett
