Tecumseh 8hp Barely Throwing any Snow...
Old 01-07-10, 02:45 PM
I have a tecumseh 8hp snow blower. I started it up a couple of weeks ago (up until then it had been working fine).
When i began to use it the august and impeller both were spinning however the machine was not able to throw snow out of the chute.
This morning, I decided to try it again. It was BARELY throwing snow out (its not throwing the snow out with as much force as it used to) after I did the following: put the gearbox in reverse and run the auger for a few minutes, then put it in drive on the highest speed.
Anyone have any idea of what might be going on, and what I should look for?
Thanks!!!!
Old 01-07-10, 02:57 PM
check that you are engaging the impeller belts or that the belt is still tight
Old 01-07-10, 04:24 PM
indypower1's Avatar
Please post the make & model number of the snowblower. Tecumseh is the engine.
First, check the shear pins and make sure they are there and not broken. If they are there, then your belt is worn causing it to slip and needs replacing.
Remove the belt cover & check what 38racing sugested.
Old 01-07-10, 06:24 PM
Okay.. I thought if the shear pins broke only the augur would stop working? I'm probably wrong so I'll double check the pins.
The augurs and impeller are both rev'ing so I am guessing it's the belt. From what it seems like the snow blower is actually made by Tecumseh, i can't find any other branding on it aside from "TECUMSEH".
Old 01-07-10, 08:18 PM
you might have to post picture then to get it id'ed as it wasn't made by tecumseh
Old 01-07-10, 09:18 PM
indypower1's Avatar
The augers will turn with no load on them if the shear pins are broken due to rust. Yet, when they hit resistance the augers will stop turning.
Look on the back panel between the tires. That is where the ID number usually is. Many times, tho, it has been painted over.
Old 01-08-10, 07:40 AM
bontai Joe's Avatar
As Indypower said, many times the augers will rotate, even with broken or missing shear pins due to friction between the auger and the shaft inside the auger. Might even spin with some snow in it, but as slippage increases, the speed of rotation decreases, and the snow coming out the chute gets slower and slower.
