OH
01-08-10, 05:14 PM
Bolens snowblower, tecumseh engine
I have an old Bolens snowblower Model no. 625 serial no.02002544. that I have some questions about. 1. Where can I find a manual for it, 2. Where is the Engine no. on this tecumseh engine, it looks to be about a 5 or 6 hp., 3. How do I adjust the carb., it has two adjustment screws, one in the bottom of the bowl and horizontaly on the left side of carb ( looking at the choke plate.
NH
01-08-10, 06:47 PM
The "625" means 6 hp, 25" cut. The engine number should be under the electric start button, on the fan on top of the engine. This is a fairly old machine, so the numbers will be hard to read.
Carb adjustments start at 1-1/2 turns out from lightly seated on both. The bottom screw is high speed. The side screw is low speed. Low speed affects idle to 1/4 throttle. High speed affects above 1/4 throttle.
You may be able to find a manual on Ebay.
NH
01-08-10, 07:04 PM
Just found this on Ebay.
BOLENS SNOW BLOWER MODELS 524 THRU 1032 SERVICE MANUAL - eBay (item 370312324535 end time Jan-26-10 19:14:35 PST)
It is listed as a "Buy-It-Now" only auction, so act quickly before some one else buys it. Seller is only in PA. so you could have it by mid week.
