Electric hedge clipper
Old 06-16-00, 12:22 PM
Post
I don't know if this is the proper forum...
I have a Black&Decker HT400 hedge clipper that stopped working. It first lost power (although corded it was similar to using a battery powered tool with old batteries.) I then noticed a burning odor from the motor. I was going to guess the problem is the brushes in the motor but I don't know how to check.
I can get a whole new one from B&D for about $35.
Do I fix it (try to) or replace it? Am I on the right track thinking brushes?
Old 06-18-00, 09:05 PM
Lightbulb
Hijaffe
The symptom you discribe with your electric hedger doesn't sound like that of burnt brushes.
If the cost of a new hedger replacement is only $35.00, buy a new one. Then take apart the burned out one and find out what did burn up.
My guess is the A/C to D/C converter electric circuit board overheated.
Which may have happened normally from age or from a lack of air flow do to clogged or restricted air intake vents.
Good Luck,
TomBartco
