02-05-10, 10:19 AM
Troy bilt tiller
I bought a used pony tiller last weekend, I know I should have listened to it run but for a hundred bucks I took it. When I tried to start it fuel flooded the carb and came out the muffler. I checked for a float to be stuck but its a five horse pulsating carb briggs. I changed the diaphram gasket (old one was torn) and I replaced the gasket at the carb and gas tank. now it is gas starved. I checked the fuel line to the tank and the screen and tube are clear. It will run with starting fluid. Could it be a cracked grommet in the breathing tube? and what is trueing the gastank. thanks in advance
VA
02-06-10, 04:07 AM
Hi Jaybrd, I posted some questions on your other post, yours is the older carb, very simple
When you replaced the gaskets did you clean the carb?
Is the tank clean?
Also you might want to check the fuel mixture screw to see if it is not turned to far in. Out 3 to 3.5 turns to start from fully closed is a good place usually.
I am not sure the term "trueing the tank" but it might mean making sure where the carb sits on tank should be flat and clean, just a guess.
Does the plug get wet when trying to start? Is the fuel fresh?
I am sure some of the more qualified persons here will post, but to me these are some good things to check.
Good Day
Is the tank clean?
Good Day
GA
02-06-10, 11:33 AM
Try choking it with your hand and see if it will start and run. If so, and it doesn't clear up after doing this, the carb needs to be removed and cleaned. Make sure you replaced the fuel pump diaphragm and put the spring and cup in place properly.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
