Noma / Murray Snowthrower, Impeller removal
Old 02-13-10, 07:28 AM
I badly damaged the impeller on my snowthrower. It's a model E2784-000. I don't see a clear way to remove the impeller. I removed the augers to make some room. I don't see pins through the impeller shaft holding it in place. Any advice?
Old 02-13-10, 01:00 PM
indypower1's Avatar
You need to "split" the blower housing from the tractor drive, then remove the belt pulley, then the impeller will come out.
Old 02-13-10, 01:57 PM
Done. It was a bit of a job but I got it out. Bad news is I bent the heck out of the impeller when I picked of a large rock the other day. The good news is after some work with a torch, pipe, a large vise, and some muscle I was able to get it back into reasonably good shape. I'm beat. I'll put it all back together tomorrow.
