homelite420 not throttling up
Old 02-14-10, 02:43 PM
my snow thrower has no throttle contol and will not increase rpm's . i thoroughly cleaned and inspected the carburetor (found rust near the float valve)sprayed carb cleaner through all orifices and didnt find any obstructions . after reassembling,it still wont increase rpms,choke on /or off. is there an easy fix to this? or do i have a vacuum leak somewhere causing this condition.
Old 02-14-10, 03:36 PM
Will it throttle up if you move the throttle on the carb manually. If it does the problem is likely in the governor or its linkages.
Old 02-15-10, 07:38 AM
throttles up manually
Yes it will throttle manualy. whats the procedurefor adjusting the governor correctly ?
Old 02-15-10, 03:24 PM
i just tinkered with it a little bit and bent the spring tab up a little bit. the tab that attatches the spring to the governor rod. it seems to be operating a little better under a load. i tested it on some wet heavy snow , not exactly what it was intended for. do you have any homelite 420 links that i can check out. my machine is missing the primer bulb(removed by me and capped off because it was dry rotted and leaking fuel)and there seems to be a spot next to the fuel line that is empty and im sure something was there prior to me obtaining this machine. thanx in advance for your help.Beer 4U2
