Snowblower dies under a load
Received 0 Votes
I have a Craftsman 22" 5HP snowblower with a Tecumseh Engine (Sears model # 143.045003) that starts and runs fine until it is under a load where it stalls. The carb is not adjustable, I have disassembled and cleaned it thinking it may have been a lean condition. This did not help. The compression is 80 PSI while cranking with the electric starter. I am not sure what the compression should be. Any ideas? Thanks.
80 lbs compression is fine. Problem is the main jet (bolt on the bottom of the carb) is clogged. There are 2 holes in the jet. The bigger hole is very visable. The smaller hole is waht causes the problems as they are overlooked due to they can not easily bee seen. This smaller hole is located in the threads and is only a tiny pin hole.
Received 0 Votes
Thanks. When I had the carb apart, I saw 2 small holes at the bottom of the jet below the threads, and I cleaned them out with wire and carb cleaner. I will check again tomorrow
Thanks again for the help.
Received 0 Votes
The two most common problems with this carb is 1) dirty bowl nut, which has already been discussed and, 2) the little O-rings on the main jet.
Look at 36 of the Sears breakdown of the carb.
thanks,
thanks,
Received 0 Votes
Thanks to all, the problem appears to be fixed. As per 38Racing's suggestion, I started back with the basics and found that the fuel flow seemed a little weak. The fuel line makes a 90 degree bend as it comes out of the fuel tank, and it was partially collapsed. I replaced the line, but need a snowfall to be 100% sure of the fix. Thanks again for all of help!
Received 0 Votes
Thanks
Thanks again. a 90 degree shutoff would be a good idea for several reasons, as there currently no shutoff. I see you are in Lake Winnapisakee. I have been going to the Laconia Classic for years staying in that area.
