Sthil edger
Jack B.'s Avatar
AL
02-26-10, 04:58 PM   #1
Sthil edger
I've gotten a Sthil FC75 edger in and it was choking down whenever I would try to accelerate it. I rebuilt the diaphragm carburetor and replaced the filter in the fuel tank...and it still does the same thing. If I keep the choke on full...it then seems to run OK. Anyone have any ideas as to what may be the problem?
marbobj's Avatar
IA
02-26-10, 05:48 PM   #2
If you have a two stroke that.....
* Starts OK cold and bogs on acceleration its probably a rich mixture in the idle circuit.
*Starts hard cold and bogs on acceleration with a high idle it's probably a vacuum leak which can be at the crank seals (and is likely on older engines).
*Starts OK cold buts bogs on acceleration and runs OK with the choke on it probably a lean fuel mixture = fuel delivery to the carb or plugged circuit in the carb. If the idle is normal there's not enough fuel to delivery the engine to the high rpm/load circuit.
*Starts hard or not at all, but has spark and hand-fed fuel it's usually the compression.
Jack B.'s Avatar
AL
03-02-10, 07:56 PM   #3
Marbobj, would you mind explaining what you mean by the term (hand-fed fuel)...that is a new one for me?
marbobj's Avatar
IA
03-02-10, 08:56 PM   #4
Teaspoon of gas/oil directly into the spark plug hole. It takes the carb out of the equation.
First you remove all gas from the carb/tank. Then clear the combustion chamber with full throttle and no plug - spin engine over a few times. Then gas in the plug hole (hand feed it).
hopkinsr2's Avatar
Non-US
03-02-10, 08:56 PM   #5
Marbobj means manually feeding fuel into the spark plug hole or the carb to rule out a fuel delivery problem... This is a great way of eliminating a carb problem without spending a lot of time tearing a carb apart & later find the engine is worn out.... Hope this helps... Roger
