solenoid on murray
smenguy's Avatar
AL
03-07-10, 06:15 PM   #1
solenoid on murray
I have a Murray rider with a briggs 287707 14.5 hp engine. My problem is that I am not sure if the solenoid is good. It does not make a sound when I turn the key but will start fine if I put a screw driver between the connections on the solenoid. I have charged the battery. could it be the solenoid is bad? thanks for your help.
Giles's Avatar
AL
03-07-10, 07:42 PM   #2
The problem is most likely the Ignition switch. Also check all wires associated with switch.
smenguy's Avatar
AL
03-07-10, 08:05 PM   #3
thanks Giles, I will check the switch and wires.
cheese's Avatar
GA
03-08-10, 12:20 AM   #4
while the switch could be bad, I find that the solenoid is the problem more than half the time. Do you have a test light or voltmeter? Check for power at the small wire plugged on to the solenoid when trying to start. If 12 volts is there but the solenoid doesn't click, the solenoid is bad. If power is not at that wire, there is another problem and we'll go from there.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
