Funny
indypower1's Avatar
NH
03-10-10, 05:04 PM   #1
Funny
I just ran into something I had never seen before. I was working on a snowblower. Just trying to do a "quickie" fix for a customer as we will most likely only have 1 or 2 more "plowable" storms this season.
Snowblower won't start. Pull the spark plug (FireSpark brand), gap is good, color looks good, connect wire, ground the end, pull the rope, nice blue spark. Pour an oz of gas down the plug hole, install the plug, pull the recoil, nothing. Repeat. Nothing.
Pull the plug. Wet. Blow it off, check it for spark-great spark. Install. Pull it over. Nothing. Compression is 80lbs. well lets try a new (champion)spark plug. Pull it over. Runs like a top!!!
Now I start looking over the FireSpark plug closer. Holding it upside down and looking thru a magnafing glass, it still looks good. Turn it right side up and look ove the insulation thru thr magnafing glass. No cracks-nothing. I put it down on the bench to answer the phone. I go back and look at it again with the magnafing glass while it is sitting on the bench and I see the problem. The insulator tip is up against the ground electrode. I pick it up to look at it upside down, and now the insulator is where it should be. Turn it as you would install it, the insulator drops down. First time I have ever seen this. Not really surprised since it is a cheap no name spark plug. And this is why a cheap spark plug is NO bargin!!
Tolyn Ironhand's Avatar
MN
03-10-10, 06:16 PM   #2
Good story! Thanks!
Electrical AC/DC and lighting Moderator
Professional Electrician, Handyman, all around swell guy!
40,000 people die in auto accidents per year in the US. We should ban cars.
cheese's Avatar
GA
03-10-10, 11:27 PM   #3
Ha! Yep, I've scratched my head over the same exact problem before. Doesn't happen often for sure.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
pugsl's Avatar
NC
03-12-10, 03:31 AM   #4
I had 1 of those in a car about 25 years ago. Lucky I could find miss on a scope.
