Troy-Bilt shredder vac model 47279
Received 0 Votes
I have an old shredder vac model 47279 and I need a spark plug wire and new oil stick. Any ideas on where I can find parts and a manual with part numbers? The Troy-Bilt website does not even recognize this model number!
Find what you have for an engine (briggs, Tecumseh, etc) & take the engine numbers, (often found on fan shroud by the spark plug) to your local small engine place... They can fix you up with parts using the engine info.... Roger
Aws Hpkins mentioned, you will have to find the numbers on the engine along with the brand. Your model is most likely at leats 20 years old. MTD bought TroyBilt in the late 90's. Yours is the old "Graden Way" TroyBilt. Most engine parts are readily available. Just have to get those engine ID numbers.
