Briggs Inlet Seat Installation
Received 0 Votes
Briggs Engine 11 HP 252700-0620-01 on Riding Mower
The instructions for installing the Briggs inlet seat say the groove side goes "down". Does that mean the groove goes down against the carb body or does that mean that the groove points down towards the needle?
Background. Mower had sat for a couple of years before I got it. Carb was a mess - all gummed up. Soaked in can of carb fluid for 24 hrs. It took that long to get all of the gunk loose. Used compressed air to blow out all of the small holes.
When i reinstalled the carb, gas leaked out of the carb (flows up the carb nozzel and out of the carb) indicating either the needle/seat were not working or the float was bad. Float was fine - no holes.
Purchased a new needle and seat. I installed the groove side of the needle down towards the carb body. Wire end of the needle holder points away from the venturi. Gas still leaks.
Removed bowl and needle in case some dirt was causing the needle not to close. Renstalled bowl and needle. Gas still leaks.
So, did i install the needle seat correctly or does the groove point down towards the needle.
What else can cause gas to leak out of the carb other than a bad needle/seat, bad float or dirt?
Received 0 Votes
Disassembly of Briggs and Stratton Large One-piece Flo-jet Carb
I just found the link above that has the exact carb I'm dealing with. It has a good pic of the vent.
I'll clean it out and see what happens.
thanks for your help.
Robert
Robert
Received 0 Votes
I checked the float and it does not have any pin holes in it.
also, I checked the float adjustment and slightly bent out the tang so that the needle would close just a little earlier. neither of these fixed the problem.
I removed the carb and tested the float in a container of water. The float closed the needle correctly.
After blowing out the vent and testing it in water, I'm going to reintsall the carb and see if the problem is fixed. Will keep you posted.
Received 0 Votes
Carb problem has been fixed. Either the vent was blocked or some dirt was keeping the needle from sealing the seat. Either way, the carb is no longer leaking any gas.
Thanks for all of the tips and suggestions.
Received 0 Votes
I have the exact same carb (shown here: Disassembly of Briggs and Stratton Large One-piece Flo-jet Carb ). It runs fine but leaks gas.
I bought a stock B&S fuel inlet valve and seat kit (p/n 394681):
Illustrated Parts Lists | Repair Parts & Maintenance Products | Shop | Briggs & Stratton
The kit has no brass seat in it. It just has the valve (2; one is viton-tipped), the clip, and a little viton "ring", which looks like it could fit inside of my old inlet seat. Instructions that came with the kit do not discuss the seat or what to do with the viton ring. Don't I get a new seat? I thought I had to remove the old seat with a tap screw and press in a new seat. Will the viton "ring" work if I put it inside the old seat?
Thanks for any help!
