troy bilt leaf blower
I am having trouble starting my troybilt leaf blower. It will only start if i prime the carb. Once i get it running it does not run well. The cylinder is tight. I think i need to clean the carb. What is the best way to do this? It is a model tb320bf.
Yes, the carb is plugged.
You can get some ideas on how to do the task by going to u-tube and searching for "carburetor cleaning" videos.
Clean the carb & install the complete repair kit.. If this is an older unit,, You'll find the diaghragms as stiff & don't respond to the engines demand for fuel... Clean it out as SeattlePioneer suggests & put it together with a new kit... Make sure to adjust the meetering lever to the spec that can be found on the carb manufacturers website (they have Excellent service manuals)) Roger
Previous Thread
Next Thread
