4 cycle weedeater motor trouble
Old 04-06-10, 02:38 PM
troybuilt cultivator/edger model#21AT144R966 with walbro (wyl196 carb)
4 cycle troybuilt motor ,idles great,press the throttle and it picks up RPM, if you go past half throttle it stalls,when you let thottle go it idles back,and repeat.
what is the setting for needle valve for 4 cycle weedeater,is it differ than 2 cycle ?
Old 04-07-10, 12:52 AM
cheese's Avatar
Sounds like you need to clean the carb. If you have one mixture screw, it is usually best set around 1 1/2 full turns out from lightly seated.
Old 04-07-10, 04:32 AM
4 cycle motor trouble
this carb doesnt have a mixture screw
