Poulan chainsaw will not start
farmall556's Avatar
MI
04-21-10, 06:34 PM   #1
My Poulan chainsaw will not start, not even a pop. It has spark, it's getting fuel but it's not flooded. Took carb out and cleaned it. Tryed starting fluid and even with that not even a pop. Gas and oil mixture is perfect. Air filter is clean and it has good compresion. It was running fine then all of the sudden it stalled and would not start back up. Didn't run out of gas or anything it was at an idle then stalled and wouldn't start again. If you have any ideas as what the problem could be please let me know.
Thanks,
Farmall556
hopkinsr2's Avatar
Non-US
04-21-10, 07:10 PM   #2
You don't say what model Poulan it is.. If it's one of the big box store specials, pull the muffler off & look & the cylinder & piston while turning it over slow,,, Any scoring on the piston or cylinder tells you it's time to go back to the big box store for another... Good Luck... Roger
GlenM's Avatar
OK
04-21-10, 07:46 PM   #3
Could you report how much compression it has?
thanks,
farmall556's Avatar
MI
04-21-10, 07:55 PM   #4
Posted By: GlenM Could you report how much compression it has?
thanks,
Compression is about 90 psi
farmall556's Avatar
MI
04-21-10, 07:58 PM   #5
Posted By: hopkinsr2 You don't say what model Poulan it is.. If it's one of the big box store specials, pull the muffler off & look & the cylinder & piston while turning it over slow,,, Any scoring on the piston or cylinder tells you it's time to go back to the big box store for another... Good Luck... Roger
Not sure the exact model number. It's a poulan Prediter 16" 35cc....I bought it used a couple weeks ago ran great up until a couple days ago. I'll try that though, thanks
farmall556's Avatar
MI
04-22-10, 10:30 AM   #6
Posted By: farmall556 Not sure the exact model number. It's a poulan Prediter 16" 35cc....I bought it used a couple weeks ago ran great up until a couple days ago. I'll try that though, thanks
Took the muffler off checked the piston and cylinder both are good. Any ideas? Maybe timing is off I'm not sure?
