Northstar Pressure Washer not spraying solution
Old 04-30-10, 07:47 AM
Angry Northstar Pressure Washer not spraying solution
I have a Northstar model M1578112G 3000 PSI pressure washer. The pressure washer works fine, unless I try to use the chemical injector line. It sprays water just fine, but will not draw chemical solution from the chemical hose into the system. I tried all the normal solutions, no clogs present in the line, the pump has oil, proper nozzle, etc. Any ideas? I really don't want to lug this thing back to the store......
Old 04-30-10, 09:08 AM
I never use the siphon feature on my PWer as I feel using a pump up garden sprayer does a better job and is better for the pump ..... but if I remember correctly, they won't siphon under pressure. Try the siphon without having the pressure on.
Old 04-30-10, 09:25 AM
I'm not sure exactly what you mean. I have the garden hose connected to my pump inlet, the pressure hose and spray gun connected to my pump outlet and the chemical hose submerged in a bucket of cleaning solution. How do I turn the pressure off??
Old 04-30-10, 02:43 PM
cut off the motor
need more characters
Old 04-30-10, 03:48 PM
cheese's Avatar
Correct, it is not supposed to siphon chemicals while it is pumping high pressure.
