briggs 4.5Q governor spring needed?
Old 05-02-10, 05:04 AM
T
Hi I have a :
10C902 0189B1 03072154, briggs 4.5 Q on a push mower.
The engine was running rough. I took the carb apart and cleaned it and the gas tank and then replaced the diaphram with the kit that you can get. I noticed however that the governor spring was damaged....it has been stretched out.
Can someone tell me what part number I need for the governor spring ? The engine "type" I have is not listed on the briggs web site. Thanks.
Old 05-02-10, 05:17 AM
G
you need to take a closer look at the type number,oftentimes the stamped nums are hard to read, i have to use a magnifying glass sometimes for these old eyes.
hth
Old 05-02-10, 05:20 AM
T
i looked at it 3 times and cleaned it off.....the numbers are right
Old 05-02-10, 05:39 AM
G
you can go here:
http://www.milacalawn.com/parts.asp
and follow the 10C902 series,
the spring(s) are mostly the same for all.
hth.
