Ryobi BC30 Throttle cable is stretched
StumpWhacker's Avatar
FL
05-04-10, 12:22 PM   #1
Do I have to take apart the trigger assembly to tighten the throttle cable or is there an easier way to do this?
Thanks.
Tolyn Ironhand's Avatar
MN
05-04-10, 12:31 PM   #2
Ones I have seen there is a set screw on the carb. Loosen that and you can then slip the cable through. I have not seen a cable stretch, it may have loosened up already.
Electrical AC/DC and lighting Moderator
Professional Electrician, Handyman, all around swell guy!
40,000 people die in auto accidents per year in the US. We should ban cars.
BFHFixit's Avatar
KS
05-04-10, 06:42 PM   #3
Cables do stretch and plastic parts wear. You may well have an adjustment for the cable on the carb mounted end of the cable, otherwise, if the plastic for the trigger has worn or the cable stretched, it may require parts.
FL
05-05-10, 07:30 AM   #4
Can you do pictures on this site?
Thanks to you both for replying back to my message.
Gunguy45's Avatar
Super Moderator
AZ
05-05-10, 07:46 AM   #5
http://forum.doityourself.com/electr...your-post.html
Vic
"I sometimes wonder how some people ever made it to adulthood..."
FL
05-05-10, 01:46 PM   #6
Posted By: Gunguy45 http://forum.doityourself.com/electr...your-post.html
Thanks. I'll post a few pictures of my BC30.
FL
05-05-10, 05:01 PM   #7
http://img340.imageshack.us/g/pic011c.jpg/
After looking at the weed eater again I noticed a black L shaped bracket that holds the throttle cable which is attached via a star screw.
I tightened this up and the cable is now taut. Of course this was after I messed with the screw on the throttle which I assume controls the idle? I'll check this out tomorrow when I try to start it.
Thanks for all your help.
