Craftsman 917-376152 Have to keep pushing primer
Old 05-04-10, 04:50 PM
When the engine is cold I have to prime approx 12 times to start and then keep pushing the primer to keep it running until it warms up. I have cleaned the carb and replaced the gasket and it still dies unless I keep priming.
The gas is fresh. Craftsman Model 917-376152 Walk behind, self propelled.
Thanks ahead for any info you can give me.
Bob
Old 05-04-10, 07:52 PM
indypower1's Avatar
You still have some dirt in the carb. You need to soak the carb in a carb cleaning solution. Make sure you also soak the main jet. Also check the air cleaner housing where the primer is located. Those passageways could be clogged, too.
Old 05-09-10, 07:35 AM
Indy is right. I had the same exact issue. I replaced the plug, primer bulb and air filter and it still persisted. I took the carb off and removed the bowl. There was some sediment in the bowl. I emptied that and sprayed inside of the carb down real well with carb cleaner and put it back together. Runs like a champ again!
Trackbacks are On
Pingbacks are On
Refbacks are On
