Carburetor bowl removal
Old 05-08-10, 02:02 PM
How can I remove the float bowl from a briggs and stratton model # 28U707 engine> It has the fuel shut off solenoid on it. I can remove that but then am not sure what to do next. Is there a nut that also comes off or does the bowl come off with out any more part removal ? I am asking because I think the float needs to be cleaned. When trying to start engine the combustion chamber loads up with so much fuel that the starter cannot spin the engine. Thanks for any insight.
Old 05-08-10, 02:09 PM
indypower1's Avatar
Depends on which carb you have. The Wlabro you just unscrew the solenoid and the bowl should come off.
The Nikki looks like you unscrew the solenoid and 2 screws on the outer edge of the bowl.
