Feartherlite weedeater
When I start my weedeater(taking care to follow manufacture instructions)It starts fine while fully choked.As soon as I take it off choke it revs for just a second then stops.Ive double checked gas mixture...It,s drivin me crazy....Thanks
How old is the unit, How many seasons?
And is the fuel filter clogged?
Did this start from the 1st time you tried to start it this season?
Do you use a fuel stablilzer like Store-n-Start or Stabil?
You'll need to check the condition of the fuel lines and primer for cracks/pinholes. If they are bad, replace them. If not, the carb needs to be removed and cleaned.
Thank you for your quick reply.I just got this weedeater at a yardsale where it seemed to run fine.The lines look like they are in good shape...I,ll let you know after I work on it...Thanks again...Rick
