Sears Mower Blades Engagement Cable...
Old 05-23-10, 05:39 AM
Angry Sears Mower Blades Engagement Cable...
Ok...
Sears model 917.276813
OEM Part #175067 (*Clutch Cable)
The "Clutch Cable" that engages/disengages the mower blades has broken.
I can not get a grip on how to go about getting at this thing with removing the steering assembly and entire housing.
Maybe I am looking at this thing wrong???
Any help would be great. THANKS!
Old 05-23-10, 11:49 PM
cheese's Avatar
It just unhooks from the engagement arm, squeeze the tabs together to get it loose from the bracket under the dash and pull it out, unclip it from the deck and unhook the spring and it's out. It's a 5 minute job.
Old 05-25-10, 08:43 AM
Ok, I have a mechanical engineering degree, so excuse the "ignorance"... I could design this thing, but GETTING to is another thing. I don't see anyway to physically get to the cable under the dash to squeeze the tabs together.
Is there "interferance" to remove first, or just do a squeeze play??? ha ha ha THanks for your input Cheese
Old 05-25-10, 07:05 PM
cheese's Avatar
Some models have a gas tank in the way and you can take the two tank bolts out to gain better access. That's about it. I just work my arm in there with a pair of pliers after removing the tank on models with the tank under the dash.
Old 05-26-10, 08:43 AM
Thanks, I figured out that removing the tank would gain me access. Your input is greated with many thanks!
Greg
