pwh 2500 pressure washer
Old 05-23-10, 02:20 PM
H
5.5hp, 2.2gpm pwh pressure washer, honda gcv 160 engine.
engine will not start. fuel is in carburator, no apparent flow obstructions, runs 10-15 seconds with shot of either. New spark plug fires witth good strong spark. first time to use this spring, ran well last summer when stored in garage. magnito problem would not start on starter fluid would it? help!
Old 05-24-10, 12:31 AM
cheese's Avatar
Received 138 Upvotes on 127 Posts
It's a carburetor problem. You'll need to remove the bowl and clean the carb and the holes in the bolt that holds the bowl on.
