Craftsman Power Washer
dwaall's Avatar
OH
05-25-10, 06:32 AM   #1
I have a Craftsman Power Washer Model 580.752191 which I purchases in 2009 but did not use only added the oil. I tried to start the washer on Sunday and would not start. One monday it started and ran for only 30 minutes and then would not start. Any suggestions?
Gunguy45's Avatar
Super Moderator
AZ
05-25-10, 07:33 AM   #2
Did it have gas in it since 2009? If it did, it probably needs to be drained and refilled with fresh. Drain it completely, including the carb. Add some Seafoam (available at auto parts stores) and see how it goes.
When it ran for the 30 min, did it stop on its own..or did you stop it, then it wouldn't fire?
Do you have spark?
Vic
"I sometimes wonder how some people ever made it to adulthood..."
dwaall's Avatar
OH
05-25-10, 08:01 AM   #3
Power Washer
I had not gas in the power washer and the machine stopped on its own.
bontai Joe's Avatar
PA
05-25-10, 08:19 AM   #4
I'm sorry, but I gotta ask, did you check to see if the fuel tank is empty? I know some are small enough that a half hour under load will run 'em dry.
Gunguy45's Avatar
Super Moderator
AZ
05-25-10, 08:32 AM   #5
And it may have a low oil shutdown? Sometimes new engines use oil more quickly I believe??
Spark and fuel would be the first things to check.
Vic
dwaall's Avatar
OH
05-26-10, 04:41 AM   #6
Powerwasher
Never started. Took back to Sears as under warranty. Sending off to get fixed. Had plenty of gas and oil. Sears also tried to start.
