PA
05-26-10, 03:43 PM
Troy Built 2500 Pressure Washer won't start
My washer is about 1-1/2yrs old. Worked no problem until a few days ago. Clearing off debri from between patio blocks about 5-days ago. Worked no problem. Used it for about 2hrs. Turned it off. Went to finish the job the next day. Went to start it up per the manual directions. Fuel valve was on, choke was properly set, ignition switch was on. Pulled the rope several times. Would not start. Let it sit. Tried again. Would not start. Smelled gas. Figured I flooded engine. Let it sit for over an hour. Tried again. Still would not start. That was two days ago. Any idea what is wrong and what I can do to fix it without taking it in to a repair shop?
