Craftsman GT3000 Dies while mowing
Old 05-26-10, 03:57 PM
The 30A fuse blows while mowing. This is a 6 speed Kohler 23hp V-Twin. Mower Model # 917.275010. SN is
042501A002856. Could it be the seat switch shorting out? I think it might be a dead short or a worn wire rubbing somewhere shorting the tractor out. I didnt see any worn wires. So, switch bypass/replacement time? The engine starts and the voltage gauge does go to the right considerably at idle, but the engine doesnt stop, and idles ok. It stops only when mowing. Sometimes it goes 5 minutes, sometimes 20. I wonder if it might be the clutch safety switch, if there is one...or a deck switch? I was reading previous threads for a clue. I dont have one at this point. Beer 4U2
Old 05-27-10, 12:29 AM
cheese's Avatar
The safety switches won't cause this. This could be caused by a faulty pto clutch, among other things. Disconnect the clutch and turn the switch on and run it awhile and see if it blows a fuse. If so, it is something in the wiring or switches. If not, the clutch is bad.
Old 05-27-10, 07:31 AM
I took the couling off the tractor and heard a rattling
coming from the bottom of the engine where the drive
shaft/pulley is. I feel like because I dont know
the first thing about electrical, and disconnecting clutches... looks like a large repair bill. I will try to figure it out first.
Thanks for your help.
Old 05-27-10, 07:45 AM
BFHFixit's Avatar
There are only two wires under the mower frame. Should be a connector on top of the clutch that just unplugs. Might have another connector for the same wires above the frame too.
Old 05-27-10, 09:24 AM
cheese's Avatar
The rattling underneath is probably the bad bearings in the pto clutch and that is most likely why it is blowing fuses. The clutch bearings gone bad allows part of the clutch to rub the electro-magnetic coil and short it out.
