Rough Idle-Ryobi Trimmer CS30-Help
Old 05-29-10, 09:00 AM
G
Arrow Rough Idle-Ryobi Trimmer CS30-Help
I have a Ryobi CS30 string trimmer Model RY30020B year 2005.
It will start fine and idle. After running a few minutes you use it to cut and release to idle it will die out. The spark plug looks fine, air filter is clean, gas mix is fresh. When acclerating it is still missing and running rough. Whwn you let go it will die out. I need some good starting points. It will even do this with the spool head off too. Starts great. Need help.
Old 05-29-10, 11:12 AM
cheese's Avatar
Received 138 Upvotes on 127 Posts
Sounds like carburetor trouble. Check the fuel lines and primer for cracks/holes and if none, open the carb and clean it out.
Old 05-30-10, 05:43 PM
G
Cheese -- any information on instructions of opening up the carburetor? Any video links or instructions? Thanks
Old 05-30-10, 09:56 PM
hopkinsr2's Avatar
Take it apart & put a kit in it.. When you find out the manufacturer of the carb, go to there website, Most of them have a manual online & they will help you a lot... Roger
Old 05-31-10, 01:50 PM
G
It is a WalBro looks like a number on it of 512.
