help: need a diagram breakdown of carb...
Old 05-30-10, 08:06 AM
Question help: need a diagram breakdown of carb...
If anyone can tell me where i can get one, i'd really appreciate it. Its on a husqvarna lgt2654 garden tractor mower. The float needle valve was stuck so i took the carb off and removed the float bowl and pulled out the neddle valve with the small rubber tip, ( i don't know what would cause it to stick i tried spraying carb cleaner in it before taking it off but it did'nt work.) The only reason i need a diagram is because when i removed the float bowl an o-ring about the size of a nickle fell out on to the table and for the life of me i can't see where it goes... I'm wondering if instead of going in the carb it might have gone in the small hole where the vacummn hose goes thru the wall of the air cleaner housing (its about the same size) and fell out when i turned it over.....thanks guys for any help with this i'd really like to get this put back together....the model # is 445877,typeis o760 e1, and the code is 071018yg.....the name on the carb is NIKKI, And the number stamped on the carb is 792947 2667712-911.......Oren
Old 05-30-10, 10:01 AM
BFHFixit's Avatar
Old 05-30-10, 10:54 AM
thanks, but i had already been to thier site and i can't find any illustrated view of the the carb there.....hoping maybe one of you guys might have one i could borrow....thanks
Old 05-30-10, 01:24 PM
BFHFixit's Avatar
Page 5 of the IPL ?
Old 05-30-10, 01:31 PM
it does not show a break-down of inside the carb.
Old 05-30-10, 01:40 PM
BFHFixit's Avatar
It does on my computer
It shows a breakdown of every part that comes off or can be replaced.
ref #'s 1123 and 1124a
Old 05-30-10, 02:19 PM
ok got it thanks, the pdf page was not showing up completely on my screen..... now i'm back in business
Old 06-03-10, 02:37 PM
B&S Carb Parts
I am looking at the B&S page you suggested for motor 98902-0110-01. In the parts diagram, it shows a check valve in the carb. but, I can't find it in my carburetor, and the diagram does not show exactly where it is. Where the heck is it?
