Toro WheelHorse Riding Mower PTO Safety Switch
Received 0 Votes
I loaned my 1999 Toro Wheelhorse Model 15-38 HXL and when it was returned the brass lever at the rear of the mower used to disengage the hydrostatic transmission was loose and would not return to engaged. The Briggs and Stratton 15.5 HP engine still starts and runs strongly, and I can drive the mower forward or back. However, when I attempt to engage the PTO the engine cuts out as though it is a safety interrupt switch issue. I have never had an owners manual and cannot seem to locate a schematic on line. I have a fantasy of a simple spring needing to be reconnected or replaced so I can have my very reliable and much used mower back! Thank you for being here and any help you can provide.
It sounds more like a seat switch. If the PTO safety switch was bad, you should not be able to start it.
If you are able to drive it however, IE: release the clutch, that is confusing unless the seat switch has been tampered with.
If you can find the model of tractor (label under the seat?) perhaps I can find some literature...
Received 0 Votes
Model number is 15-38 HXL --- wouldn't a seat switch affect the ability to start it? Also, please note this is a hydrostatic drive - no clutch needed to "shift" from forward to reverse, no real gears in forward. The clutch is only used when engaging the PTO. Thank you so much!
I need the model and serial number that is specific to your mower. There should be a label under the seat with both. Model should start 13A..... maybe 14A.....
The brake pedal in this case I was referring to. With the parking brake engaged you should be able to start the mower with out an operator in the seat. If the PTO switch is not activated it should not start regardless of the seat being occupied or the brake being locked.
Ok. Still could use those numbers to find an IPL and possibly schematic,
The PTO switch "should" IIRC be under the steering column near, and activated by the lever.
Try engaging the PTO and see if the mower will start.
Received 0 Votes
Model No. is 71221 and Serial No. is 9911449
Nope, mower does not now and has never been able to be started with the PTO engaged. There is a key required for mowing in reverse, which is engaged and something I have always used.
https://lookup3.toro.com/classes/doGetPub/?pubid=14036
Page 19 electrical schematic
The key also adds another possible element to the problem.
I never like to "eliminate" any item involving electrical until the actual problem is found and resolved...but it should be enough confirmation to continue diagnosing elsewhere.
I have not had to trouble shoot this system so I am a bit unfamiliar with it.
One thought, might try engaging the PTO with the reverse key activated. If it works in that mode I would certainly suspect that NMIR module, even if not I still do...
cheese will probably be along this eve and have the one check confirmation...
