Help replaced fuel pump on BS 8hp pressure washer
I replaced the fuel pump on a 8hp Briggs and Stratton pressure washer and accidently forgot to mark where the hoses attach to. I have three inlets on the fuel pump a hose coming from the gas tank, engine case and carburator. Does someone have a photo or diagram I could please see to put this back together... thank you so much
after thought lol
after thought lol
Are there not arrows marked on the pump body by 2 of the 3 fittings??? If so the arrow pointing in is the inlet,, the arrow pointing out is the outlet & the one not marked is the pulse line.. Yours may be different, but most pumps are marked like this.. Did you get a Briggs pump or an Aftermarket one??? Roger
I don't see any marks on the pump and yes I ordered it directly from B&S It is a square fuel pump with one port on top and two on the bottom.
does the port on the bottom closest to the engine go to the fuel tank or is it the other bottom line and which port goes to the carberator?
thanks for all your help guys and gals
