Homelite weed eater won't start
Browndav's Avatar
OR
06-02-10, 02:34 PM   #1
I have a 25cc Homelite Weed Eater that was never the easiest to start, and just recently decided it won't start. Before when it started it would run just fine.
Engine plate says: XH2XS.0254RA
So far I have:
-Removed carb, took the needle valve out, and soaked everything in some chem dip for a few hours. Used the air compressor to blow all the passages out afterwards. The gaskets looked fine when I had them apart.
-Priming bulb sprung a leak so I replaced it; when priming it does circulate gas, then stiffens up as the bowl fills up.
-I don't see how to get the filter out of the tank, so I hit it with carb cleaner & compressed air from both sides. Both fuel lines are not restricted and pliable.
-Compression is right at 90psi with throttle open or closed.
-Gas is brand new (from yesterday) and ethanol free. The mixture is 32:1.
-New spark plug - with the plug out and resting on the the engine body I do get spark; can't tell if the spark is good or not though.
-Spark arrestor and muffler are not restricted.
What am I missing? Only other thing I haven't checked is if the spark is at the wrong time (is that even possible?)
Any ideas would be appreciated Beer 4U2
BFHFixit's Avatar
KS
06-02-10, 02:51 PM   #2
Replace the carb diaphragms. No holes does not = ok
Browndav's Avatar
OR
06-02-10, 03:58 PM   #3
Alrighty, after a few trips back and forth to the shed, I figured out it has a Zama H39A carb on it, and takes RB-29 or GND-18 kits.
Other than the RB-29 including the needle valve, are they otherwise the same? They have some different gaskets, but I think the ones I need are in both.
(on ebay)
RB-29
GND-18
BFHFixit's Avatar
KS
06-02-10, 04:20 PM   #4
GND-18 looks to be it. You could prolly find it locally, save time n shippin n such.
Browndav's Avatar
OR
06-03-10, 12:13 PM   #5
The local small engine shop had RB-29 in stock, so I picked that up.
Got it all installed, and the weed eater works again
There was one big difference I saw between the old and new gasket wear-wise. Apparently it was enough to make a difference.
Thanks Beer 4U2
