Ryobi 725r 31cc 15" connector broke off inside
Old 06-05-10, 11:39 AM
H
Question Ryobi 725r 31cc 15" connector broke off inside
The connector piece from one of my Ryobi attatchments broke off inside my Ryobi 725r. Is their a way to remove the broken portion so I can continue using with my other attachments? Please advise. Thanks.
Old 06-05-10, 12:04 PM
BFHFixit's Avatar
It should just slide in and out. Might try a good magnet, a pick, shake it, or may have to drill a small hole and thread a screw into it or some such.
Old 06-05-10, 12:16 PM
H
I guess I jammed it in initially, then upon removal broke the entire attachment off, which is the reason it's not sliding out. I will definetly try all ideas until one works. Thank you so much for your advice and for your quick response.
