How long is too long?
Old 06-04-10, 05:34 PM
This is a carb cleaning question. I purchased a bucket of carb cleaner and plan to soak a carb in the solution.
Can you keep it in the cleaning solution too long? If yes, how long is too long?
Steve
Old 06-04-10, 07:15 PM
indypower1's Avatar
The carb cleaning solutions on the market today are tame. They do the job. I have left carbs in the solution for 2 days.
The old stuff that you could buy in the early 90's was harsh. It would dry out your skin quickly, take paint off, eat up rubber & plastic. EPA mandated it be made less harsh. This stuff will disolve varnish, but it takes longer. The old stuff would clean in an hour. The new stuff, I soak for min of 2 hours and many times overnight.
Old 06-04-10, 07:36 PM
Thanks. I bought the stuff at Autozone last weekend. So the carb goes for a long swim. Thanks.
Steve
Old 06-04-10, 09:02 PM
hopkinsr2's Avatar
You'll be fine,,soak it as long as you want... I've a carb in my "Kleen-Flow" stuff from a snowblower left over from early spring... I looks clean now, but I just keep it there as I throw lawnmower carbs in with it.. No time to fix snowblowers now!!!! Roger
Old 06-06-10, 08:24 PM
Quick update: After four hours in the carb cleaner the engine started on the third pull. The first two pulls were probably needed to pull the fuel through the carb and back to the engine. It started several additional times on a single pull.
I think I will do my snow thrower carb next.
Steve
