B&S Walk-behind Running Slow all of a sudden?
DatacomGuy's Avatar
GA
06-04-10, 08:57 PM   #1
Have had my mower for 3 years, do proper maint. in recommended intervals.
The other day I was mowing, and went under shrubs with the mower, and the engine almost died. I pulled back on the mower, and it saved from stalling but now runs very slow and essentially not usable in tall grass. Luckily I was just about done.
I must have hit something with the shrub branch that affected timing or something on the front of the mower.
Any thoughts or suggestions ??
hopkinsr2's Avatar
Non-US
06-04-10, 09:07 PM   #2
You hit the throttle & bent the linkage... Find where the spring attaches @ the front under the air filter & bend it outward while listening to the engine.. When it sounds as it used to,,you're good to go.... Roger
DatacomGuy's Avatar
GA
06-12-10, 11:31 AM   #3
Thank you! I will work on it this weekend. I've been searching for this answer all over, so much appreciated!
SeattlePioneer's Avatar
WA
06-12-10, 12:18 PM   #4
As long as you are working on the self propel feature....
How often do idler or other pulleys that a part of a self propel system need to be taken apart and greased? I have an MTF and Arians mower where the idler pulley needed grease, didn't get it, were seized up and damaged and needed replacement.
Is that something worth maintaining if you are doing other work on that system?
DatacomGuy's Avatar
GA
06-12-10, 12:55 PM   #5
Mine isn't self-propelled.. Not sure if that matters.
indypower1's Avatar
NH
06-12-10, 05:06 PM   #6
Posted By: SeattlePioneer As long as you are working on the self propel feature....
HUH? No self propelled mentioned in this thread.
