Burns front tine tiller
pkimbrough's Avatar
TN
06-07-10, 03:23 PM   #1
i have a burns front tine tiller with a briggs and straton 5hp motor, i need a manual, but the model number has worn off. i am trying to figure out why it is not firing. i have checked the obvious: spark plug, wire, oil, gas, i have even checked the flywheel for rust. i'm thinking it might be the coil. i am trying to fix it before my husband does. he is very frustrated with it. i want to see the look on his face when i fix it. c'mon guys help me. thanks, jen
cheese's Avatar
GA
06-08-10, 12:53 AM   #2
The model number of the engine should be stamped into the engine shroud, probably on the side. If it has no spark with a good coil, .010" air gap between the coil and flywheel, the kill wire unplugged, and a good plug, then the coil is bad, unless this is a very old model from the '80s that has points. If that is the case, I still recommend replacing the coil with a newer style that requires no points and you can leave the old points in there, just disconnect them.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
