Help replaced fuel pump on BS 8hp pressure washer
Old 06-09-10, 10:00 AM
Smile Help replaced fuel pump on BS 8hp pressure washer
I replaced the fuel pump on a 8hp Briggs and Stratton pressure washer and accidently forgot to mark where the hoses attach to. I have three inlets on the fuel pump a hose coming from the gas tank, engine case and carburator. Does someone have a photo or diagram I could please see to put this back together... thank you so much
after thought lol
Old 06-09-10, 10:21 AM
BFHFixit's Avatar
Post the model numbers for the engine so someone can see what type of fuel pump you have....
Old 06-09-10, 12:42 PM
Good idea
I will post the model number and type when I get home tonight
Old 06-09-10, 07:31 PM
hopkinsr2's Avatar
Are there not arrows marked on the pump body by 2 of the 3 fittings??? If so the arrow pointing in is the inlet,, the arrow pointing out is the outlet & the one not marked is the pulse line.. Yours may be different, but most pumps are marked like this.. Did you get a Briggs pump or an Aftermarket one??? Roger
Old 06-10-10, 09:34 AM
Model number
model and type
192432 0193 01 960926yd
thanks
Old 06-10-10, 09:57 AM
I don't see any marks on the pump and yes I ordered it directly from B&S It is a square fuel pump with one port on top and two on the bottom.
does the port on the bottom closest to the engine go to the fuel tank or is it the other bottom line and which port goes to the carberator?
thanks for all your help guys and gals
