cub cadet lt1045 steering problem
Received 0 Votes
Hi everyone
I have a 2006 cub cadet lt1045 with the steering a little sloppy. I think that Its by the gears. What can I do to fix this problem?
Thanks
Thanks
You'll have to look and see what the problem is and go from there. If it's worn gears, replace them. If it's worn bushings that the gear shafts contact, then replace them. It may be some of both. Often the bushing at the end of the column gear wears and causes a lot of slop.
Received 0 Votes
