Stihl 011 restoration project continues
After replacing the gas lines, the engine started but will still not keep running or start again without putting some gas in the carb. So I've decided to clean the carb, and if that doesn't work, rebuild it. But a few questions arose as I got deeper into it.
1. After removing the screws that hold the carb on the engine, I was still unable to disconnect the throttle cable. Is there a trick to this? Do I need to disassemble the handle and remove the cable? There is a small brass "paddle" on the cable end that looks like I should be able to turn it somehow and remove it from the carburetor, but I haven't been able to do this.
2. In the tank, there is a fuel line with something on the end (filter?) that seems to feed the fuel line going to the carb. Is that a filter on the end? Should it be replaced?
3. There are two gas lines, one goes to the carb and the other goes to a hole in the case (I think) near the engine. Why 2?
4. The new fuel lines that I bought have minor kinks in them, though the fuel flows. Could this be a problem?
Thanks for the help!
Clean the carb well and replace the gaskets and diaphragms will likely get you going.
