Recoil Starter Problem
gokarthelp's Avatar
NY
06-17-10, 06:25 PM   #1
I'm having trouble with a 9HP snowblower engine that I believe to be Briggs&Stratton. I was trying to start it with the recoil pull start and pulled too hard. After that, the starter rope wouldn't go back in. I took the assembly off the rest of the engine and started to tool around. I wound the starter manually but when it gets to a certain point it clicks and the most of the tension is released and the rope won't go back in. Can anybody help? The housing for the spring and rope has RMI 2- on it..
marbobj's Avatar
IA
06-17-10, 08:19 PM   #2
The spring has either broken or has come out of its little notch in there. You'll have to take it apart to fix it.
gokarthelp's Avatar
NY
06-18-10, 03:56 AM   #3
how do i take it apart? there doesn't appear to be any visible screws.
hopkinsr2's Avatar
Non-US
06-18-10, 08:20 AM   #4
Your probaly best to post the engine numbers (usually near the spark plug) so the guys can tell for sure what you have for an engine. Roger
indypower1's Avatar
NH
06-18-10, 12:34 PM   #5
Posted By: gokarthelp how do i take it apart? there doesn't appear to be any visible screws.
You can not take it a part. This was stamped & pressed together. And there are no parts of the inner workings available.
This design was made for quick & cheap manufacturing, not for rebuildability. You are going to have to find a good used one or a new one. New is about $60.
gokarthelp's Avatar
NY
06-18-10, 03:45 PM   #6
thanks for the input everyone. i've been able to get it started by hand (with some difficulty) but once i get it going it doesn't seem to have much idle before it just dies.
