Tecumseh HS50 67344H Shaft size Help
Old 06-27-10, 12:16 PM
H
Hello Everyone,
I need some help with my old Tecumseh HS50 67344H gas engine mounted to a Sears chipper/shredder.
I am going to replace this engine, but I need to know the output shaft diameter and whether its tapered or not. I need to be sure the replacement will accept the chipper attachment that goes on the shaft.
Thank you for any assistance with this item,
houdinihar
Old 06-27-10, 08:26 PM
hopkinsr2's Avatar
If the engine isn't worth fixing,, Why can't you take it apart & Measure the shaft yourself to see what you have...That way there won't be any error from the forum guessing what you have for an engine,,, Usually you can look them up by engine #'s & get them right.... Roger
