17hp Kawasaki coil
Old 06-30-10, 03:27 PM
I
17hp Kawasaki coil
I have a Great Dane Chariot Jr. mower with a 17hp Kawasaki engine. Model # is FH500V AS19. The coil on my mower is part # 21171-7007. When looking at buying a new coil, The replacement coil is part # 21171-7034. It says it replaces 21171-7001, 7007, and 7013. Is there a difference in these coils or are they all interchangeable?
Old 06-30-10, 10:13 PM
BFHFixit's Avatar
In short, NO! Maybe! But the 7034 part should replace all the others.
Old 07-02-10, 03:34 AM
I
Thanks BFHFixit, for your answer. Now the reason I asked. This is a twin cylinder engine. On this mowwer I lost fire at one plug. I changed plugs first. No luck. I then assumed, Coil. I unplugged the kill wires at the coils and still no fire from one coil. I purchased a new aftermarket coil and tried it. It fired but the fire was jumping through the boot at the plug and shorting out on the motor. Assuming I bought a bad coil I returned it and purchased another. Same thing happened. On both new coils, if i plugged in both kill wires the engine would not start at all, but with just one plugged up it would start but only run on the one cylinder. I did also change the coil I know works to the other cylinder and the engine ran on that side then. Thats why I asked about the coils. Looking at purchasing a used coil just to see if the aftermarket stuff is JUNK!
Old 07-02-10, 07:10 AM
BFHFixit's Avatar
Electrically they are likely interchangeable. One universal model to fit others could have something such as slotted mounting holes to fit several applications where the original may not....
