MS
07-03-10, 08:01 AM
overhaul ticking
Ihave just overhauled a 13hp briggs and stratton snapper engine and forgot to install a new governer mech inside.
The hole that ride the cam is egged a little but not too bad(hopefully). Is there a method to "time" this or just put it in.
Will a sticky throtle linkage give more rpm than it needs and make it swing too far open. thanks for the services.
Non-US
07-03-10, 08:49 PM
What engine do you have... The # from it will help the pros... Are you saying it's surging??? If so you'll have to clean the carb in a bath type cleaner & install a kit... If it's doing something else,, be more discriptive, post the engine #'s & the pros will have you dialed in right away!!! Roger
