how to reinstall front wheel dust cap
Received 0 Votes
is there a secret to installing the dust caps on a riding mower front wheel. I removed the wheel to look at the grease fitting because every time i put grease in the fitting on the wheel after 4 or 5 squirts of grease it starts coming out at the base of the fitting, kind of like it is suppose to be that way maybe to keep the grease from pushing the dust cap off, does that make sense. Anyway if someone could tell me an easy way to get that dust cap back on id sure appreciate it.....thanks
Received 0 Votes
they are the pliable kind but very hard to get back on over that large washer, the edges bump into that washer and when i try to push it on it just kind of turns back in on itself. Just wondering if i can take a hooked tool and pull back on one side after getting the other side on
Received 0 Votes
You're right, they can be a real booger to get back on. I've found they're easier to get back in hot weather, the material is a little more stretchy and pliable. I've had some that went right on and others....@#$%
Generally, I get as much over the washer as I can, then start twisting and pushing at the same time. Maybe a little bit of oil on the inside might help.
As for me, not an expert, it comes down to use any trick you can think of, a little hook to pull out fold would help...
hth
hth
Received 0 Votes
ok thanks i got it back on by putting a block of wood against it and tapping it with a hammer. I guess the flat pc of wood put equal pressure on it and the force of the impact poped it back on before the air could escape....WOW i feel like a genius....lol
