Idle Problem and hard to start with Honda Mower
Old 07-15-10, 04:49 PM
Model # HRB 216 HXA
Serial # MAA-1092887
Engine Serial # GJAEA 1707648 MY
This is a hydrostatic model and is about 9 years old. I have had problems with it running in the past so I have replaced the carburetor, gaskets and spark plug. It runs now but is very difficult to start and when it runs without the blade engaged it surges badly. I have to choke and then back off of the choke to get it to start and it takes some effort.(many many pulls) Any suggestions are greatly appreciated!!
Thanks.
Old 07-16-10, 01:20 AM
cheese's Avatar
Sounds like your carb is in need of cleaning/repair again.
Old 07-20-10, 06:56 AM
apparently the choke is sticking and causing most of the problem
I sprayed the assembly with WD 40 to loosen up the choke to slide back into running position and now it comes out of choke ok, but goes intermittantly back into choke while running?? Any suggestions...Thanks.
Old 07-20-10, 11:09 PM
cheese's Avatar
Bad throttle cable? Is it freely moving?
Old 07-21-10, 04:53 PM
The throttle cable moves freely...but the thing I see is that the choke is engaged fully for start up. When you back off the choke at the from the cable control, the choke stays on unless you slide it back with your finger. It almost like it's missing a spring or something to pull it out of choke. Thanks for all of your suggestions...
