CANADA
07-17-10, 12:46 PM
power washer?
I have a Be Power Washer with a Comet pump (with a Honda motor) the pump was rebuilt last year and was running good until today.
The power washer starts up and ides good, until, I pull the trigger on the wand then the Power Washer stalls right away.
I played with the choke in different postions and didin't seem to make any change, stalls when the triigger is pulled on wand.
any ideas!!!!!
any ideas!!!!!
CANADA
07-18-10, 08:21 AM
Posted By: idmason60 I think you have a restriction,debris in your unloader valve or after the unloader. You might try disconnecting the hose and wand and trying to see if the pump will run.I just tried started it up with everything atteched and when I pulled the trigger it stalled. I then diconnected the wand and ran it for a fewseconds, maybe a minute.
Then re-attached the wand and pulled the trigger and ran for a bit before the tip in the end of the wand came out along with an o-ring. But did not seem to stall, so maybe I cleaned some debris out like you said.
So now the water is pissing out all around the tip of the wand. I just bought the wand 2 months ago so I will bring it back to them to fix the o-ring in it. After I get the wand fixed I'll give it another run.
CANADA
