Help, Throttle vibrates out of position of Honda self propelled HRR216VXA
Old 07-17-10, 03:20 PM
Help, throttle vibrates out of position on Honda self propelled HRR216VXA
I own a Honda HRR216VXA and the throttle control vibrates off the FAST position and into the SLOW position continually.
Does anyone with a similar mower know how to correct this issue?
Thanks!
Old 07-17-10, 07:41 PM
31YTech's Avatar
Check the spring #4 below for rust and being collapsed, If it's still in good shape you can stretch it a little to put more tension on the control lever. If the spring is too bad it can be purchased as a separate part.
Good Luck
Old 08-30-10, 08:02 PM
Follow up
I am having the same problem and was wondering if the suggested fix solved your problem with the throttle?
