Craftsman Mower Engine Control Cable
Received 0 Votes
I have a Sears Craftsman Walk Behind Lawnmower front wheel propelled (Briggs and Stratton 6.5 HP)
And I am having a problem with the engine control cable the one that goes to handle you have to hold down to start mower and hold while using mower
I was able to free up the lever that the cable attaches to but when you depress the cable it still a hard pull and pops the cable holder off the handle
I tried lubricating the cable but it got a little better but its puilling so hard the cable holder still wants to pop off handle
Is it possible the cable is bad or has a kink inside the tubing it runs through
At the moment I put a wire tie to help hold the cable holder in place
I went on Sears part and the whole assembly is only about $10.50 and seems easy enough to replace
I had trouble figuring out why the cable would be so hard to pull if the actual lever it pulls was freed up?
When you get the new one before putting it on, put oil on the cable and work it back and forth to work the lube to the areas that are going to likely rust and you will never have a bad cable again. Have a good one. Geo
Received 0 Votes
yes I will do that except the shealth covers most of the cable and it comes with the finished lugs so you can only pull it out so far on each end but I will try to get some WD40 to flow down there
