powerwasher trouble!!
Old 07-23-10, 11:14 AM
got a power washer for free because it wasnt running. it is a Chore Master 2100
http://www.etspressurewashers.com/mi...2%20020301.pdf
if i put a shot of carb cleaner if will run and imediatly shut off, then when i try right after that it will turn over but no run. today i took the carb off, cleaned the bowl and all the passages/jets and still have the same problem!
what could i do?? please help im 16 lookin for a job, tryin to get some money by fixing some small engines
:PTB:
Old 07-23-10, 03:36 PM
BFHFixit's Avatar
You could get the engine numbers and get a manual for the engine. Small Engines, Lawn Mower Engines and Generators by Briggs & Stratton
The manual you linked to says it is a Briggs 6hp OHV.
Sounds like you are on the right track with the carb or fuel system.
Did the fuel bowl have fuel in it?
Fresh gas?
Could be some passages or jet you missed or did not get cleaned.
How are you cleaning btw?
Old 07-23-10, 05:33 PM
You need to post the engine model, type and code usually found on the metal engine shroud just above the spark plug. If it has a bowl carb either the main jet, the nut that holds the bowl on, is dirty, some have holes near the bottom or the nozzle is clogged. Have a good one. Geo
Old 07-23-10, 07:12 PM
Fresh gas?
good idea, i'll look for the engine # tomorrow
Fuel i the fuel bowl: Yes
Fresh Gas: old gas flushed/added new gas before i did the carb work
Could be some passages or jet you missed or did not get cleaned: Most likely, to be honest it wasnt as thorogh as it could have been
Old 07-23-10, 07:15 PM
yes sir, i'll get those numbers up tomorrow.
i will deffinatly take special attention to those areas.
Thank You!!
